How to Make a Dc Motor Gearbox Became Servo Motor
2,775
56
10
About: I'm Eric Dirgahayu, although my education in films art director and cinematography, but I like all of thing about robotics. and i have making a many of lowcost Robots. :) find them at my youtube channel http...
using a cheap servo is the best choice to make small projects, but the bad quality of gear, easily damaged. Do not quickly make a decision to dispose of the damaged servo, you should see this tutorial first. :)
Step 1: What You Need
If you have damaged servo on the gear mechanism, and you still need it, but don't want to spend a lot of money . This is what you need :
  1. Plastic dc motor gearbox good tors, price only $1.87 http://store.extremeelectronics.co.in/6V-DC-Gear-M...
  2. super glue
  3. electro tool
Step 2: Remove the Electronic Modules
  • remove the electronic modules (motor driver) from the case broken servo.
  • on Potentiometers , cut the handle grip of potentiometer .(look to the picture no.2)
Step 3: Replacement the Potentiometer to Gearbox Shaft
  • unplug the plastic adafter shaft on the back side of the gearbox
  • make a hole right in the middle of the handle grip of potentiometer is in pieces last. make a hole the same size as the gearbox shafts
  • plug the potentiometer to the shaft gearbox, give a little super glue, make sure the glue holding a potentiometer to the gearbox shaft.
  • use a plastic plate size 1cm x 5cm (im using a PVC plastic pipe), with a hot fire flame to forming the plastik to a shape like a pic no.6
  • plug the plastik to the gearbox, holding the potentiometer on gearbox, use a little super glue. make sure the plastic stick to strong and withstand potentiometer in place.
Step 4: Soldering a Motor Output
  • solder the wires to the motor output of motor driver circuit.
  • output (+) on circuit to (+) motor input and output (-) circuit to (-)motor input.
  • plug the circuit to the gearbox body use tie band or give a little glue gun.
this the tutorial on video :
link : https://www.youtube.com/watch?v=VtqTWegwCdM
Step 5: Test and Finish (enjoy the Project :)
  • Test your new servo using RX/TX remote control or any microcontroller. if not work look back to a line wiring or check a circuit motor driver.
  • Now you have unique servo with good tors and more powerfull.
this example robot using this servo gearbox :
(for more lowcost project video https://www.youtube.com/user/ricdart1/featured coming soon on Instructables)
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    10 Discussions
    Aye Chan
    2 years ago
    Can it rotate 360 degrees and control the motor shaft position?
    eric dirgahayuAye Chan
    Reply 2 years ago
    is can if the use a 360 degre servo motor driver , if using a driver standart servo like i use in a project is can't
    robotfuture
    4 years ago on Introduction
    I gave a comment to all your Instructables, because I think all your work is amazing!! good job. just love it!!
