Mini 4 Jaw Chuck Wood Lathe
97,531
518
69
making a mini lathe had been an idea in my mind for a long time until i saw someone's. and then i made this by aluminium alloy sections and aluminium plate. but i didn't take too many pictures for all the steps because sometimes i forgot.
this lathe can be extended when you add some module. it can be a table saw, a grinder... and it will help you do many things only if you have ideas.
list of materials:
AL alloy sections length 3060: 650mm*2; 1560: 200mm*2; 3030: 650mm*2 40mm*2 100mm*1
AL plate: 120mm*100mm*10mm*2, 120mm*20mm*10mm*4
motor 220V/250w RPM forget
4 jaw chuck: Φ65mm screw thread M14*1
drill chuck: B16 joint
bearing with base Φ20mm *4
spindle: Φ20mm, one has screw thread M14*1 on the both ends, another has a B16 joint for drill chuck
motor belt: Φ6mm Polyurethane
sliding table 50mm*150mm*30mm
some screws...
Step 1: The Material
fix the rails, after rails are for the electric motor
fixed them on the epoxy plate.
Step 2: Other Parts
some hand working
Step 3: Continue Hand Working
a skill: when you use a hand saw, you can put a mirror on the opposite side, then you will never deviate.
Step 4: The Last Assemble
the drills and files were my grandfather's, they are mine now.
i fixed the dead center of lathe on a slide way.
    • Pie Contest
      Pie Contest
    • Paper Contest
      Paper Contest
    • Build a Tool Contest
    69 Discussions
    crazypj
    5 years ago on Step 3
    What a great idea with the mirror, in all the years I've been working it's the first time I've ever heard of it
    Thanks
    zacker
    lol great idea with putting a mirror on the other side of the cut to watch the saw and make sure it stays on line..
    steelsunzacker
    Reply 5 years ago on Introduction
    This skill was copy from a carpenter near my school when i was a child.
    zackerhohum
    Reply 5 years ago on Step 4
    Yeah... what's that stuff called? is there a "Common" name for it? Id like to look into getting some. Is it just "Aluminum Extrusion"?
    AJMansfieldzacker
    I think its just aluminum T-slot framing, like the stuff listed here: http://www.mcmaster.com/#80-20-compatible-t-slotted-framing/=n1a5s8. Even if its not, you could do the exact same thing with T-slot framing, and then it would be compatible with T-slot stuff.
    zackerAJMansfield
    cool. I did go to the link that steelsun provided to the ebay seller.. lotsa cool stuff.
    I am wondering if this stuff would be strong enough to use as a frame for a small, benchtop mill?
    AJMansfieldzacker
    It most definitely would be strong enough, assuming you use the proper fastening hardware with it. If it isn't strong enough for a larger one than that, you could just use double-extrusion framing.
    steelsunhohum
    I think the AL extrusions have different standards in different places. They have different spare parts, joints, links, but i think they are similar, so you can choose the kind that you can get easily and cheap.
    hohumhohum
    I was gonna ask about the steady rest,, i see the piece in front on the black hinge, brilliant design
    steelsunhohum
    the knife rest was linked with a hinge, if i don't want to use the knife rest i can turn it down.
    Buick455
    Ok, the only parts I'm still a little unsure about are the spindles, pulleys & chucks. Could you post links to those parts or part numbers? Ty for posting a parts list Steelsun :)
    What I mean as "large" is not length, but width. They have many sizes available in metric, 20mm up to 45mm.
    I get all of my stock there.
    http://stores.ebay.com/8020-Inc-Garage-Sale/Extrusions-Metric-T-Slot-/_i.html?_fsub=6479547&_sid=129537225&_trksid=p4634.c0.m322
    I get my extrusion materials here :
    http://stores.ebay.com/8020-Inc-Garage-Sale?_trksid=p2047675.l2563
    I don't get stock as large as shown, but they do have it available.
    SparkyOR
    Excellent. A little more info on the headstock and tailstock would be good, & of course parts list and sources would be helpful also. You have 90% of a Taig style metal lathe.
