No Churn Ice Cream Recipe
376,326
1,426
149
About: I work at instructables by day, and turn into a stitch witch by night. follow me on instagram @jessyratfink to see what i'm working on! ^_^
This recipe is a game changer! With just three ingredients, you can make fantastic and creamy vanilla ice cream at home with absolutely no churning or ice cream maker required.
Yup, you heard that right - awesome homemade ice cream - NO ICE CREAM MAKER REQUIRED! :D
This no churn ice cream is sweet and smooth - perfect for summer! I want to play around with mixing other flavors in soon. I think peaches would be absolutely heavenly in it.
Step 1: Ingredients
  • 2 cups of heavy whipping cream
  • 14 oz can of sweetened condensed milk
  • 2 teaspoons of good vanilla extract - I'm using Nielsen-Massey
  • a container for freezing in - I'm using an 8x4 loaf pan.
The only real thing to worry about here is using a high quality vanilla - if you use something cheap, chances are you'll taste more alcohol than vanilla. The flavor just won't be as good!
Original recipe found here. Thanks, Martha!!
Step 2: Whip the Heavy Cream
Make sure the cream is nice and cold before you start! Sometimes I even put the bowl in the fridge too.
Use a hand mixer (or sheer muscle!) to whip the cream just until you get nice stiff peaks. When you pull the beaters out and the cream stands up, you are done. You'll be able to tell it's almost there when the beaters begin to leave very defined lines in the cream.
Just don't over whip - if the cream starts to separate, it won't work for this recipe.
Step 3: Mix the Vanilla and Condensed Milk
Pour the condensed milk into a bowl and add the vanilla on top. Mix well until you can't see any darker streaks in the condensed milk. :)
Step 4: Fold Everything Together
Pour the vanilla and condensed milk mixture gently into the whipped cream. (Normally you'd do this the other way around, but since it's a small amount of condensed milk I say just go for it!)
Use a spatula to fold the two together. This will take a couple minutes or so - you want to go slow and steady so you don't whack all the air out of the whipped cream.
The top photo shows what it looks like when it's still streaky - the second photo shows the mix when it's ready!
If you haven't folded ingredients before, check out this video for an explanation.
Step 5: Pour Into a Loaf Pan and Freeze
Use a spatula to help scoop everything out of the bowl into the loaf pan. Smooth the top out slightly, but don't press down on the ice cream or be rough with it - you really do want to keep all that air in there!
Place in the freezer and let it firm up for 4-6 hours minimum.
Step 6: Serving
This is a little different from traditional ice cream - it definitely melts a little faster! I don't recommend letting it sit on the counter too long to thaw - maybe 10 minutes max. The top layer and sides can go very soft and it's hard to get the original texture back if you let it hang out too long.
To serve, dip a ice cream scoop in hot water and dry it off. Use that to scoop it out without thawing it too much.
Enjoy! If you make it I'd love to know what you think. :D
3 People Made This Project!
  • Fat Challenge
    Fat Challenge
  • Pie Contest
    Pie Contest
  • Jewelry Challenge
    Jewelry Challenge
149 Discussions
SaudaminiN1
Question 6 months ago on Step 6
I used regular cream, it didnt thicken..what can I do now?
LisaD87
3 years ago
I added a capful of Kahlua , and it won't freeze. It's like really soft, soft serve. Any tips?
skylaneLisaD87
Reply 9 months ago
Good "Kahlua" is easily made from sugar, vanilla, coffee and alcohol. Really good "Kahlua" has a bit of glycerine in it.
Put your Kahlua over your ice cream when you serve it.
Dealcoholize your Kahlua with a vacuum pump.
Being that vanilla ice cream already is already vanilla flavored, just add coffee flavor to the ice cream.
My freezer will turn 80 proof vodka icy slush... something you really really REALLY don't want to think about swallowing.
ithica2012LisaD87
Reply 2 years ago
use strong instant coffee or strong brewed coffee instant cappuccino worked well also so does cold brewed coffee but it has to be strong.
Chuck666ithica2012
Reply 9 months ago
Us Turkish ground coffee if you can find it you’ll get all the coffee for everyone
srilykLisaD87
Reply 9 months ago
Alcohol has a much lower freeze point than water. Maybe research how to freeze alcohol?
JosephS119LisaD87
Reply 3 years ago
I add two tablespoons of alcohol when I make mine, It takes about 6 hours to freeze properly. Using root beer extract instead of Vanilla is really good. I use Vodka when makeing the root beer, made a chocolate caramel (Coco powder and caramel condensed milk) I used burboun to make that.
VictoriousVixenJosephS119
Reply 2 years ago
You add vodka with the Root Beer Extract? Do you use this exact recipe that you add it to? If not, may I have your recipe for the Root Beer Ice Cream you make? :) Also, do you have a blog?
Chuck666
9 months ago
My late wife and I made lots of ice cream the traditional method but this sounds like a wonderful alternative. Thank you!
porcupinemamma
2 years ago
Ahhhh Man! Did you have to post such a cool post? It looks deeeeelish! Thanks Jessieratfink. You rock :)
MrsJ9T
3 years ago
I have been making lemon ice cream for years. Same ingredients - double cream, condensed milk, juice and zest of 3 lemons and 3 limes (I love lemon but if you want a milder taste only add juice of 2) For another variation, crush some ginger nuts and chop some crystallise ginger. Swirl through and freeze.
MrsGCMrsJ9T
Reply 3 years ago
Equal quantities of extrathick double cream and condensed milk with the juice and rind of 2 lemons is a recipe I know as Lapis (it means Stone). If you leave it to cure in the fridge for as long as you can keep your hands off it, several hours, or even a day or two - it will set very firm. The longer you leave it, the firmer it gets. Hence the name Lapis, as it turns into a cheesecake consistency. Beware, though: too much lemon juice will keep it liquid, rather than reacting with the fat in the cream to solidify.
VictoriousVixenMrsGC
Reply 2 years ago
You just leave it in the fridge? Or the freezer? And you also use 3 lemons? (Lemons with their rind and juice, correct? And the same amounts of cream & sweetened condensed milk as this recipe? Do you also add the vanilla?) I'm very interested in trying your recipe! :)
MrsGCVictoriousVixen
Reply 2 years ago
Hi, sorry for the delay in replying, I had trouble accessing my account. Yes, just mix it and leave it. I recommend in a fridge due to environmental factors which might turn the cream off. Lapis depends on the reaction between the acidic lemon juice and the fat content of the cream to clot. Lemon posset has a similar structure, but I think that's cooked. The condensed milk is only there to sweeten it. I haven't tried it with lime juice, but I know orange juice wasn't very successful.
I also make a low-fat version I call Pumice, but it doesn't solidify because there's no fat in it. So I use extra-thick natural yoghurt (eg Greek set) and either lemon curd or a lemon dessert packet mix for flavouring. The sweetness comes from the addition. In the UK I use Green's. Lemon Dessert Mix. I just add the dry powder to the yoghourt and let stand for a couple of hours so the powdery, potentially slightly acrid taste mellows and smooths. My supermarket sells that in the packet dessert aisle. Please note that Pumice is a low fat not a low sugar recipe :)
MrsGCMrsGC
Reply 2 years ago
Re-reading your question, I'm sorry I'm not familiar with U.S. measurements. Whatever size of condensed milk I use, I use the nearest size tub of extra-thick cream. Technically Lapis isn't an ice cream recipe, you definitely don't freeze it. It really is more like a cheesecake topping. Yes, the lady who taught it me used the shavings from the rind (zest) to create something far livelier than I can do. On that note, however, my Lord inspired me a couple of years ago to toss lemon zest in the tiniest bit of butter, just long enough to release the oils, not long enough to cook. That _really_ upped the flavour of the zest. I have also caramelised lemon zest for a cake topping by cooking it in a dry pan with a sprinkle of sugar for several minutes.
MrsJ9TVictoriousVixen
Reply 2 years ago
recipe:
3 lemons, zested and juiced
3 limes, zested and juiced
300ml double cream
1 can of condensed milk
Place all ingredients in a bowl and mix with hand mixer until just thickened. You can then chop up some crystallised ginger (to taste) and some roughly crushed ginger biscuits and swirl these through. Another variation is to just swirl some lemon curd through. Place mixture in a freezer safe container and leave until frozen. It will set very hard so be sure to take it out and rest on the counter for about 10 minutes before you want to serve it.
If you want to make a vanilla version, then just leave out the lemon juice and add 2tsp of good vanilla extract instead. I also make a coffee ice cream. I make a strong mixture of coffee granules mixed with about 2tbsps of hot water and mix it in. I really just play around with flavours, next time I am going to add mint flavour and chocolate chips.
VictoriousVixenMrsJ9T
Reply 2 years ago
This sounds fantastic!! Since I've never made this before, how much crystalized ginger would you think I should add? The pieces here are around 2 inches long, by 1/2 inch. And how many Ginger biscuits for this batch, if they are flat, and around 3" inches across? Also, the coffee version - your coffee granules? Is that instant coffee powder? Or coffee grounds? And how much mixed with the 2 Tbs water? I'm asking because I really don't want to mess it up the first time. lol Your lemon version, and the one with the Lemon Curd are pretty straight forward, so I understand that easy. Oh, and lastly, you do, or don't, whip the cream before adding it to the rest of the ingredients in each recipe? Thank you, Mrs. J! You're very kind, and friendly, in offering to share your personal recipes with those trying these types of recipes for the first time. Thank you again, so much! :) :) :)
Reply 2 years ago
we Love ginger so I use 3 to 4 thumb sized pieces. Chop them up very fine to swirl through use about half a packets of ginger nuts which I think is about 150g, maybe 200g, leave them chunky. I use a combination of coffee granules and grounds. 1 tbsp of strong coffee granules, dissolved in about 2tbsps water and a tbsp of coffe grounds just mixed through. It will almost look like little vanilla seeds dispersed through the ice cream. I don't whip the cream first. Just add all the ingredients together in one bowl and whisk with a hand mixer or stand mixer I mix until well combined and that should do it.
