Picnic Table
555,421
1,753
88
This instructable is for a large diy wooden picnic table which is easier to step in than a traditional picnic table.
It is made completely of two by fours (89x38)
Supplies:
Step 1: Layout - Cutlist
second pic is metric ,third imperial.
If you are going to use a miter saw remember that most miter saw gauges are set up off 90 degrees to the back of the fence! (http://www.thisiscarpentry.com/2011/07/29/miter-angles-miter-saws/).
So for 51,2 degrees you have to set your saw to 38,8 .
Step 2: The Two Benches
I used some m8 threaded rods to connect the leg constructions.
In total is have used 24 each 16 cm and have cut them when the table was ready.
Some coach bolt will even look better.
For the other connections i used wood screws of 80mm.
Click on the pictures for a larger version of the picture.
A google sketchup version can be downloaded here
Step 3: The Table
For the legs of the table you need to cut out a piece for each leg.
Step 4: Screw It All Together
The legs of the table must not be lower than the connection two by fours .
The horizontal connections are 50mm of the floor so it won't wobble on an uneven surface.
Step 5: In Inches
Step 6: In Inches (fractions)
32 People Made This Project!
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
88 Discussions
UrviC
Question 3 months ago on Introduction
Hello ,
Pls let me know which wood have u used for outdoor ?
JoeE10
3 years ago
Would you be able to post a cutting list for this build as it would help people know the amount of lumber needed. Much appreciated.
JuansimancasJoeE10
Reply 9 months ago
On the first images it's the cutting list and in different colors for the diferent parts
André BJoeE10
Reply 3 years ago
I added an extra step .
mayby not a cutting list but maybe it helps.
JamesP466
Question 1 year ago on Step 3
On the picnic table, where you have to cut a notch for the legs, can ou give me some more details? Beginner here.
michael086
1 year ago
Hello,
Could you tell me what size screws did you use.
It looks very professional.
Well done.
Rajen5262
1 year ago
I'm new to this too, what it the total length of timber for the whole project?
AlexM286
1 year ago
Do you have the above images in feet (') and inches (") by chance?? Great design!
fjhuman
2 years ago
Can someone please clarify on the Imperial measurements? This may seem like a silly question. But for measurements such as 11,69 or 13,08, how are these suppose to actually be read? 11" and...? How does the 69 translate?
fjhumanAndré B
Reply 2 years ago
Amazing, thank you! Will be trying this out today.
marvinfb79
2 years ago
What type of wood did you use? Treated or untreated?
RyanR146
3 years ago
What were the degree of the legs cut to ? Me and my buddies have been stumped for over a day now and we've done multiple different calculations and cannot figure it out
tchase1
3 years ago
nothing like showing somethng that people would be interested in,providing a link to download the instructions only to find out that they want you to pay for them.
TracieH1
3 years ago
I built this table but I altered the plans that would accommodate a glass top. I will post pictures when I get the other one built. I am excited to get it all done. Mine is also connected. I figured it would be best for better support since the glass weighs 250 lbs.
MasonN4
3 years ago
cutting list ??
