Pumpkin Teeth
58,825
991
56
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
Halloween isn't the same without pumpkins. This year, take your pumpkins to the next level by adding some terrifying teeth! These toothy mini pumpkins were made by adding plastic vampire fangs in a mouth opening. This simple trick produces great results, and is super easy to do. No special carving required!
This is a fast, fun, and easy project to complete. All you need to make your own are:
  • plastic vampire teeth (mine glow in the dark)
  • mini pumpkins
  • sharp knife
Ready to make some scary pumpkins?
Let's go!
Supplies:
Step 1: Scoop Innards, Make Mouth
scoop innards:
Cut an opening around the stem of the mini pumpkin so you can scoop out the guts and seeds. Using a spoon, dig out the pumpkin insides, save the seeds to roast later.
mouth opening:
Look for a large surface to place the mouth. Using one of the plastic teeth as a reference, small marks were made on the surface of the pumpkin for the mouth opening.
A rough rectangle opening was cut for the mouth. The mouth opening was then shaped with a knife to fit the teeth.
add teeth:
The teeth are friction fit into the mouth opening. For elongated pumpkins with larger mouth openings the teeth can be separated, then pushed into place.
Step 2: Eyes
Carved pumpkins are going to need eyes. And, there's no wrong way of adding them.
Painting is a fun and colourful method to give your carved pumpkin sight. I found a pile of googly-eyes and was able to use hot glue to stick them to the pumpkin surface. For those who love power tools, another option is to drill round openings.
Experiment and have fun. The eyes are very expressive, and can make these vampire teeth fun or scary.
Step 3: Optional: Add Tealights
The real trick to these toothy pumpkins are that the teeth glow in the dark, but that doesn't mean they can't be lit up like regular jack-o'-lanterns. Since the cavity inside these mini pumpkins is so small, I used LED tea lights so that they wouldn't burn.
The tea lights work to charge up the glow in the dark teeth, so if you turn them off the teeth will glow.
Step 4: Optional: Appendages!
Maybe your mini pumpkins aren't terrifying enough. With a few wire coat hangars you can get creative and give your pumpkins some appendages.
Wire coat hangars were cut and straightened, trimmed to uniform length, then bent into shape. I made spider legs of one pumpkin, and arms for another.
You're ready to display these adorable toothed pumpkins around your home or office. This fast and fun project is a great twist on the classic carved pumpkin, and there's loads of room to personalize.
Have fun!
Have you made your own pumpkin with teeth? I want to see it!
Share a picture of your version of this project in the comments below and be awarded a Pro Membership!
Happy Halloween!
2013 Autodesk Halloween Contest
Finalist in the
8 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Arduino Contest 2019
  • Party Challenge
    Party Challenge
56 Discussions
Manyhats
2 years ago
Very creative and terrific photos!
T0BY
3 years ago
Omg, these are AMAZING!
alicemalicelolotox
Reply 3 years ago
Thanks! This site is so inspiring! Halloween is my favourite time of the year!!! And I love all the Halloween themed instructables!!!
mikeasaurusalicemalice
Reply 3 years ago
Ha, kitty pumpkins are great!
Thanks for sharing pictures, Enjoy the Pro Membership.
alicemalice
3 years ago
Ok I made three kitty pumpkins...
alicemalice
3 years ago
I made a kitty pumpkin
KerriM4
3 years ago
Great ideas! Thanks for sharing!
db85
3 years ago
Genius!
pyotryllych
3 years ago
awesome looking teeth
thundrepance
4 years ago on Introduction
all of your choices for EYES cracked me up, mikeasaurus .... the drilled round ones remind me of DOMO :D {i love domo}! the one with the hands in the air made me laugh out loud!! ( ;^D
mikeasaurusjdavis8
Reply 5 years ago on Introduction
Are those teeth stuck in the top of the foreground pumpkin? Yikes!
Thanks for sharing your pumpkin teeth, enjoy the 3-month Pro Membership and digital patch.
