Striped Wood Stool
20,400
466
25
About: I'm an Italian freelance structural engineer, graphic designer and photographer, and I'm teaching physics in Waldorf schools. I always investigate electronics, robotics and science in general, I'm a passiona...
To add a nice colour effect to a wood stool, a friend of mine had the smart idea to insert some coloured stripes in the wood board.
As you can see from the picture, the effect is really cool. Although a good result is mainly obtained with a good artistic talent, I will here describe the steps of the making process, so that you can try by yourself.
Step 1: The Wood Stripes
To obtain the wood striped you can both colour some wood boards and then cut the thin rods from it, or you can also paint directly the rods. Difference is light, but you will see a different detail along the edges.
If you have different wood types, try to keep some of the rods with natural colour, you will add wax at the end.
Step 2: The Boards
To make a couple of stools which make a pair, but not too much equal one each other, this project considers to cut in a complementary way the two boards.
Indeed you have to remove the central part of one board, and the external parts of the other, like in the picture.
To remove the central part you can both use a circular saw or a milling machine.
Step 3: Choose the Colours
Now make some test in arranging the coloured rods in the grooves. There is no need that the rods are all on the same plane, since a bit of difference in height will make a better appeal. Here is the step in which you have to free your artistic talent.
Step 4: Glue and Insert
When you are satisfied with the stripes disposition, take the out and glue them, keeping joined with some vises.
When the glue is dry you can insert and glue the three groups of rods in the right grooves. Also in this case use some vises to tighten them in place.
Step 5: The Legs
Now we have to make the legs for the stools.
Draw the shape of this supports as you like, but try to make a central hole for each of them, since you have to add a central bar as reinforcement.
Make holes for wood plugs, both in the top surface of the legs, and on the bottom side of the wood board. You have to choose the same diameter of the plugs you will use.
Also add a wood profile over the short edges if you wish to cover the extremity of the thin bars.
Then glue everything, tighten with vises and let it dry.
Step 6: Add the Bar
Add some rods inside the hole, so that this new bar will improve the stability of the stool.
To make the bar stronger it's better that you glue all the rods together, then glue the group into the holes.
Step 7: Finishing Touch
To finish the stools you can add wax and some wood treatment, so to increase veining look and durability of the material.
Here you can see the second stool in its full beauty and complementarity!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    25 Discussions
    ReginaW9
    9 months ago
    I know this post is old but....instructable says" colored" wood. What did you use? Latex paint, acrylic, a marker?? It is a very cute stand.
    andrea biffiReginaW9
    Reply 9 months ago
    A maker never becomes old, and neither his instructables ;-)
    You can use water colours but also acrylic ones, I think to remember they were water colours.
    billb6
    4 years ago on Step 7
    these look nice but I can't see anything here that would make this an 'instructable'?!?
    more like a picture or two of what you did and have.. not how to actually do anything...
    maybe this will be better in a category of inspirational... as in, ' hey all, look what I did.. you can do this too, if you know how'...
    anyways.. it does look good...
    Tampaguybillb6
    Reply 4 years ago on Introduction
    Hey "billb6" - Lighten up! Yes, it's simple, but there's enough info to inspire some people to give it a go. And the results are pretty cool.
    redwood00
    4 years ago
    This is so simple; and yet so BEAUTIFUL! Thanks for making the time to share.
    tcristian
    4 years ago
    well done... :)
    lindarose92
    Beautiful and very well done! I saw it today but I didn't recognize your style this time, I miss the redish background :D
    better not, actually I'm not the real author of this stool, I only helped a friend of mine to build it and I wrote the ible ;-)
    shazniandrea biffi
    Congratulations! !!! And thanks for the nomination :-). I'm so honored you thought of Me :^)
