T-shirt Printer
156,035
238
42
this instructable is for making a t-shirt printer from a canon c86
you can also print on wood like  is shown on the video link , is the same concept.
Step 1: Tools
1.- epson c86 Ink jet printer
2.-SHEET OF PLY WOOD 4X4
(or whatever material you choose)
3.-6’’ OR 4’’ WIDE NO SKID TAPE
4.- DRILL AND 13/32’’ DRILL BIT, SCREWDRIVERS.
5.- HOT GLUE GUN
6.- 26’’ DRAWER SLIDER (2)
7.- 5 0R 6 OF 1’’ WASHERS
8.- HAND SAW OR TABLE SAW
Step 2:
Ok so lets begin
First ting is made the shelf
The sides go on the outside of the bottom (use some nails or screws to assemble the pieces,
Step 3: Drawer
The Drawer
the sides mount on top of the bottom,
Step 4: Material Holder
Now were going to make the material holder (this is were all the different material are going to laid so that they can be print on )
looks like a T shape like this :
T
You will need to cut 2 pieces first one is going to be 13x9 inches and the other
is 13 x 3 3/8 inches
Step 5: Drill Step
ok all the parts are finish
the shelf, drawer, and the T shape.
Ok next step is to drill a 13/32 inch hole in to the shell for the printer driver shaft which rolls the drawers (this will be explain later wen we get to the printer ) pick up one side to be the front. Now drill the hole one side of the shell 6 ½ inches to center by 2 3/8 inches from the bottom., Repeat the same on the other side.
remember that these need to be as straight as you can so that the shaft rolls straight.
Please look at the picture with the shaft install :
Now mount the drawer slide on to the right side It 1 ¾ inches from the front and 5/8 inches from the top.
Step 6: Step 6
Now take the slide part out of the drawer slide for easier mount the drawer,(you can also mount the drawer after you mount the shaft in place
Mount 2 inches in from the back of the drawer and ¾ inches from the top
Now apply the No skid tape to the bottom of the drawer centering from side
Step 7: Disarme the Printer
OK NOW THE NEXT STEP IS TO TAKE THE PRINTER APART AND MOUTING IT ON THE DRAWER SYSTEM
Ok here is the victim a epson c86 printer
Before webagain dismantling the printer remember that this will void ALL warranty with the printer!!! So if you cannot afford to lose a printer, don’t try this project.
First thing is to test the printer make sure the printer works like normal install the ink and print a test page.
NOW LET’S START TEARING THIS THINGS APART!! : )
Remove all the plastic tops from the printer (a small flat head screwdriver will be needed)
Start with the bottom tabs, then the back tabs, do both sides
The bottom tabs which actually release the top,
DO NOT REMOVE THE TIMING BELT
Step 8: Naked Printer
while you were taking apart the bottom the pump and gears may have come off, its ok. Just don’t loose any parts,
now release the drive shafts from their position:
take the driver belt off and the screw in between the gears,
now cut out the frame...
this is Wat will look like wit out the plastic covers and all of the cuts
Step 9: STEP 9
NOW you're ready to mount the printer on to the drawer and put the belt on to the shaft
and we need to hack the paper sensor just put some paper wit some hot glue on it or some piece of plastic.
 now the printer is ready to print just put the t-shirt holder and  a t-shirt (white or lite colors only ) to make a test : )
Step 10: Finish Machine : )
you can put some  of the plastic cover back to the printer
thank you all for you're attention on my first instructable hope it helps some one.
thank you.
  • Safe and Secure Challenge
  • PCB Contest
    PCB Contest
  • Toys Contest
    Toys Contest
42 Discussions
batvanio
12 months ago
Not that I do not like the idea, but the ink from these printers is washed and the first wash will be removed. The ink is water-soluble.
JohnE288batvanio
Reply 2 months ago
They make Ink cartridges for making iron on logos and what nots for most printers. For regular printer ink just soak them for 30-45min in the washer add 1/2-3/4 cup vinegar and 2 tsp salt that will set the ink so it doesn't wash/fade out.
batvanioJohnE288
Reply 19 days ago
And then will not the smell of vinegar smell then? Vinegar usually uses it to clean, for example, microwaves. Does it keep a mixture of vinegar and salt ink safe? Just asking. I'm not much with you about chemistry. Also, will not change the color of the picture. I'm only doing a screen shot with handy means. Unfortunately, it is not suitable for sophisticated without any special things. I used a simple cut out of paper on which I put a frame with a mosquito net. I have seen a light sensitive plaque, but here in my country I do not know where it is, and the chemicals for making it are not particularly safe.
idijdjaht
Question 7 months ago
Do these plans apply to c88 aswell and nx215
idijdjaht
Question 7 months ago on Introduction
I have a c88 and nx215 can i apply same basic steps for my first build ever n my life looking for some. Plans for those two epson printers plz help
josh716
11 months ago
i want to buy 1 contact me
RetgXmen
1 year ago
Exelente
josh716
1 year ago
thank u agguilar
opendtg
2 years ago
We have posted some Free arduino diy dtg plans: opendtg.com
tovey
5 years ago on Introduction
Best ink to use is the same ink for making iron ons.
After printing directly to the t-shirt, you need to heat press the shirt in order to set the ink into the t-shirt material.
It is possible to print on black t-shirts, but you will need white ink.
Yes it is made.
Google
direct to shirt printing -screenprinting
Or
Direct to Garment -screenprinting
for more information.
NimaR1tovey
Reply 3 years ago on Introduction
Hello, I know you last commented a year ago, but in regards to the dark color printing, do you just purchase white ink? How do you hook it up to the printer? If anyone sees this please respond it would make my day :) Thanks
rajivshahiNimaR1
Reply 3 years ago
for printing in dark colour garment, i think you need different printer (usually ones with 5-6 ink) so you change one ink to white. and it needs a software as well to control the ink flow when white ink is in use instead of the original colour.
PatricioE2NimaR1
un cartucho negro que no ocupes cárgalo con blanco y ya estando en la impresora dale limpiar cabezal para que agarre el color blanco (si es que encuentras un cartucho vacio del modelo de tu impresora)
PatricioE2
excelente tutorial lo acabo de hacer con una impresora HP me costo con lo del rodillo pero genial...
