The True Diyers Screen Printing
138,783
636
144
I'll show all you cheap people how to screen print. I build or make %99 of my stuff. This is probably the cheapest way of doing screen printing. Only thing is, is that you will have to want to make many screens for it to pay off. But I've made many screens and truly love making people shirts, and even more.... saving money.
Supplies:
Step 1: The Screens
the screen frames are pretty easy from scratch, I use 3/4 inch wood (lying around, so it doesn't truely cost me anything) and cut 1- 1 1/2" strips. I then make 45 degree cuts on the corners. My screen's dimensions are usually 18" X 17" for a regular design but for full shirt designs I use 21" X 18". but after the 45degree cuts have been done they should all set flesh with each other. now take out your pressurized staple gun and shoot each corner this should hold the frame together. Now its time to stretch your fabric.
Step 2: Stretching the Fabric
now its time to do the most annoying part of screen printing... stretching the fabric. if anyone has performed either stretching a canvas or made a projector screen will be familiar with this process. To start out you will need the fabric to stretch. I buy mine at my local wal-mart the fabric needed to do this is called a "mesh" fabric, if your not %100 on fabrics ask a employee they are sure to help you out. most of the time I buy my fabric for $2 a yard so it ends out being pretty cheap. Now its time for the sketching of your newly purchased fabric, I start out with 1 staple on each side and progressively add 2 to each side making sure that I tug on the fabric as I go to each opposing side. after a while and a few hundred staples I finally finish my screen.
Step 3: WARNING: HARMFUL CHEMICALS Aka Phto Emustion
Step One: make a sensitizing solution
Use rubber gloves, apron, and eye protection.
This is toxic and can penetrate skin.
14 grams of Potassium Dichromate (from ceramic chemical suppliers)
4 fluid ounces of water.This can be stored in a dark glass bottle in a dark place for several months. I bought my potassium from ebay, 1lb for $20 (including shipping) this proves beneficial if your doing A LOT of screen printing cause 1lb = 543 grams. Elmer's glue is like $.25 each so I stocked up.
Step Two: make a photo sensitive emulsion
Use rubber gloves.
10 parts Elmer's Glue (by volume)
2 parts sensitizing solution
mix it
Keeps in total dark for a day or so. Work in dim light.
Use a small piece of mat board to spread the glue thinly across the fabric to close the mesh with glue as thin as possible to stop up the fabric. Work from both sides to spread it thinly.
Dry in a dark closet.
Step 4: The Design
Some tutorials will tell you to scan in art and then print them onto a transparency, this is a good way to do it. But me being my cheap self use translucent paper ( given to me from my art teacher at school so no expense there) and draw on them or trace to make my design. I use a combination of permanent sharpies to make my designs. but if you have a large or intricate designs I would stick with the transparencies.
Step 5: Exposing Your Screen
I have a reflector I bought from lowes for $8, and has proven to be worth it. since this is homemade emulsion tests will need to be done as far as exposing time goes, I know my 18" X 17" take 15 - 20 min. to expose. if you happen to try this please post your personal times and heights etc. I tape my designs down on one side. This prevents from the design moving around and since there's only one it works as a hinge and allows you to see the difference in colors from the exposed to the non exposed parts of the screen. Also if the screen is not ready the tape allows you to place it back down with out any movement of the design. ( hence referring to it like a hinge)
Step 6: Water Time
Use a garden hose or power washer to spray the entire surface of the screen with water. At first, do this with low pressure from a distance. Within 2 minutes the screen will start to open up and the positive areas will start washing away. Move closer if necessary, increasing the pressure of the hose and focusing it on any areas that do not seem to be washing away. Sorry for no pictures.
Step 7: Final Step... Printing
the final step is printing. I use nothing but a car squeegee used for cars, found at walmart for $1.80 and works just as well as the expensive squeegees people will say you "need" place a strip of ink above the design, burnt into the screen. then with little force pull the ink towards you. then go back up top and use a little more force then before.now carefully pull the screen off the fabric. This should now reveal your new DIY cheap screen printing.
Step 8: Word to the Wise
well over the last few weeks i came to the result that a cheap product called vellum (found at staples) works the best for burning your screens. also if you would like to "reclaim" your screens, all that is required is bleach. Lightly apply it to the ruined/ unwanted screen, let it set and them spray it with the hose.
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Arduino Contest 2019
    144 Discussions
    Foo_Plinger
    7 months ago
    Do you have a name/sku/item # / for the fabric you use? I just walked
    through Walmart, and saw several fabrics that *might* be described as
    mesh, but nothing jumped out as correct. Is this a tuile fabric?
    Foo_Plinger
    Question 11 months ago on Step 2
    Do you have a name/sku/item # / for the fabric you use? I just walked through Walmart, and saw several fabrics that *might* be described as mesh, but nothing jumped out as correct. Is this a tuile fabric?
    rasterfarian
    Tip 1 year ago on Introduction
    have used dichromate for sensitizing Carbon tissue back in 1957 up until today with silkscreens. I.ve always put distilled water into dicheomate powder and when the water wont absorb anymore then de- cant into bottle and seals till I need it At moment I have a bottle which I decanted 4 years ago and it is still active . I miix 1 part sensitiser to 9 part white glue with a touch blue pva tinter . Regards Rusty Hearder rustyhearder@gmail.com.
    bilgrami
    1 year ago
    has anyone tried using acrylic paste instead of elmer glue, once acrylic solidifies it last a very long time, whereas water based glue would deteriorate with multiple washing, adding di chromates in acrylic seems a good option to make emulsion, usually available for around $ 1.40 per Kg, and can last 50 to 60 screens minimum, let me have your take on this thanx.
    can i use common silk fabric find on cloth shop because i am in Pakistan and didn't find any mash fabric plz help me thanks
    bilgramiIrfanasif1
    Reply 1 year ago
    irfan are u in karachi ?? where can i get stuff locally the material etc. plz reply Thanx.
    FlipsideLokozubair mehmood
    Reply 4 years ago
    Sheer curtains work great. I even used polyester sheer fabric as a screen...was amazed at how good it worked.
    Reply 4 years ago
    I have found that the mesh count is very important if making intricate designs..but for my purpose which is soccer team shirts with big boss letters i went to local metal worker, or home depot, and purchase metalic screens. They are easier to maintain and literally pay for themselves. But they are expensive, unless your like me who has friends with very thin sheet metal laying around, and alot of patience. I hand "meshed" my first metallic screen. I have not use emulsion in almost a year. With a a cricut or vinyl cutter, die cutting machine, i draw up design on computer, sometimes by hand if it's simple, and print out the designon non-wax, or the non-shiny side of freezer paper. I get spray glue spray waxy side, this helps keep in place, i get iron and on jighest seting iron the freezer paper to my screen. Waxy side becomes sticky and remains in place. Unless you laminate it, its a sturdy enough stencil for 20 shirts. If your only doing one shirt, then you can by pass the screen all together and iron the stencil directly unto clothing. Be careful upon removing stencil. Sounds like a lot of work, and the meshing my own screen was exhausting, everything else usually takes me about 10-20 minutes to prep station for shirts.Also build my screen press.
    nfarrowzubair mehmood
    Reply 4 years ago on Introduction
    Zubair, It would depend on what kind of ink you are using such as oil base or water base. Most of the time Polyester screens are for water base ink. I would say if you use oil base ink you will have to use some thinner to clean your screens. but having a real silk screen would be very cool and most people would rather have the real deal. Just watch out for the thread count.
    CarlosR181
    2 years ago
    After mixing the sensitizing solution with the glue and put it on the mesh do i let it dry before exposing it to light? or do i need to expose it immediately after applying it?
    RuthÉ13CarlosR181
    Reply 2 years ago
    ...and what was the answer (please share)?
    CarlosR181RuthÉ13
    Reply 2 years ago
    Last sentence in step three, "dry in a dark closet."
    sarah.fukami
    a great way to create transparencies for burning is to print the black and white image on regular computer paper, then brush the paper with veggie oil until it is soaked in. this is especially easy because you can get large-scale copies from kinko's for cheap instead of having to tile separate pieces together. after it dries, it has the exact same transparency as vellum and works great. i've also found that opaque pens (used for film) block a lot more light than sharpies. they are more expensive, though.
    coask8b
    10 years ago on Step 2
    another way i have used in the past is to stretch mesh-fabric in an embroidery hoop, instead of going thru the process of making a screen.
    slimguy379coask8b
    Reply 10 years ago on Step 2
    yeah but thes are smaller and suck when applying the emulsion
