Ultimate Cleaning Formula
7,529
342
15
This formula can make pots look new
Step 1: Materials
1 cup vinegar
1 cup baking soda
1/3 cup salt
disposable cup
3 table spoon water (more or less)
Step 2:
Mix everything together(no vinegar yet). At this point a drop of lemon or dish soap can be added for scent
Step 3:
put the baking soda on the thing you want to clean, soak a paper towel in a bowl of vinegar.
Step 4:
scrub with the towel then rinse everything off (scrubbing can take a while)
Spring Cleaning Challenge
Runner Up in the
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    15 Discussions
    tomatoskins
    4 years ago on Introduction
    Wow, this is quite impressive! I wouldn't have thought that something so simple could do such a wonderful job!
    StephaansAlexZhang
    Reply 4 years ago
    Salt and vinegar makes hydrochloric acid.... Be careful of inhaling the fumes. Use gloves.
    espi
    you can use just baking soda and vinegar for an extra burnt pot or tray; bring to boil on stove and leave cool, preferably overnight, then wipe clean
    satoko68
    4 years ago
    Add some essential oils to it for extra crud-cutting power, such as lemon, orange or lower grade lavender (no need for therapeutic grade oils with this, so save yourself some money). This mix also works great for scouring off glass cooktops, bathroom fixtures/sinks/toilets etc. Although I'd dump it all in the toilet first, then use a toilet brush.
    schabanow
    Is it okay that vinegar fall in love immediately with baking soda?
    breeariella
    4 years ago
    Uhhh... so you soak paper towel in vinegar and scrub the dirty pot with the paper towel .. then discard the baking soda salt mix ?? No mention of that ??!... ConFused ...... : ¿
    AlexZhangbreeariella
    Reply 4 years ago on Introduction
    so you rub the baking soda onto the pot, then use the vinegar soaked towel to rub the baking soda off. then after it becomes clean rinse everything off
    chienline
    4 years ago
    Does it work with porcelain toilet or sink? I will give it a try :)
    KrashKing405
    4 years ago
    Using the salt and baking soda as fine abrasive, and the acid from the vinegar to clean, nice idea.
    KrashKing405
    4 years ago
