Vertical Window Planter
12,692
150
10
Everyone likes to put plants on their windowsill.  But why not take advantage of the light along the sides of the windows?
here's one way
Step 1: Cast of Characters
inexpensive curtain tension rod $3-$5.  Get one that will fit inside your window's vertical height 2 extra inches or more
8-10 empty plastic soda bottles (depending on height of your window
hot knife
tape measure
decorative paint that will adhere to plastic
spray bottle
heat shrink tubing or valve-tube attachment (5/16" female threaded coupling to 1/4" male tube coupling)
about 3-4 feet of flexible tubing (aquarium type is good)
Step 2: Prepare the Bottles
cut off the bottoms of all the bottles
cut little windows into the sides, about an inch from the bottom
Step 3: Paint the Bottles If Desired
Put the cap on the bottle and place it on a stick in the ground - this will make spray painting the bottle much easier.
Shake up the paint and spray it.
I chose a terra-cotta like color for this one
Step 4: Prepare the Bottom Bottle Cap
Remove the rubber cap from one end of the tension rod
To keep the bottom bottle from sliding off the tension rod while you are filling it with soil, cut a hole in it using the hot knife so that it will just fit on the tension rod.
Slide the lid onto the tension rod.
Replace the tension rod rubber cap.
Step 5: Add the Bottles One by One
thread each bottle one after another onto the tension rod
as you add a bottle, insert some soil and add seeds in the open windows
Step 6: Install in the Window
Take the whole thing to your window edge
Put a small dish at the bottom to collect any water runoff
Compress the tension down a couple of inches
Place in window and center in your drainage dish
Let the tension rod go
Step 7: How Do You Water It?
In order to avoid using a step ladder to water it, I came up this little watering device.
It consists of a spray bottle with some aquarium tubing affixed to the nozzle
The aquarium tubing is tied to the end of a bamboo stick to allow you to position it.
Squeeze the trigger repeatedly till the water works its way up the tubing.
Now you can water your vertical window planter easily without stairs or step ladders.
Hydroponics and Indoor Gardening Contest
Second Prize in the
  • Arduino Contest 2019
  • Party Challenge
    Party Challenge
  • Gardening Contest
    Gardening Contest
10 Discussions
rush_elixir
3 years ago
awesome...can also be use for a vertical hydroponic or aquaponics set-up
mnmama
5 years ago on Introduction
I live the watering contraption. Very clever. Please post pics once the plants get going, OK? I do think the size of the bottles are going to limit you to small plants, with small root balls, like strawberries maybe, or watercress and lettuces. There you go....salad in a window! Thanks for the idea.
foobearmnmama
Reply 5 years ago on Introduction
I will post pix - will do. Strawberries would be nice. Not sure what plants are going to show up in the winter months, this will be an interesting experiment
lynnfiorante
5 years ago
I like the idea but it looks too small for anything other than a flower plant
