Wireless Pan and Tilt Camera Rig With Arduino
13,459
42
19
this is a small arduino project with the NRF24L01 wireless Transceivers modules ans 2 servo motors.
the rig is controlled by a wireless joystick and it can hold a camera, laser or anything you can think about.
Step 1: Requirements
required tools:
3d printer
small screw driver
links to the electronic parts:
2 servo motors
2 NRF24L01 Transceivers
1 joystick module
2 arduino nano clones
2 6v battery packs
some wires
download and print 3d objects from here:
http://www.thingiverse.com/thing:708819/#files
Step 2: Making the Models and Building the Motors Base
in the video you can see the timelapse capture of the printing. all the printing process took almost 2 hours.
connecting the remote controller:
the remote controller include 1 joystick, 1 arduino, 1 NRF24L01 transceiver and a battery.
connection diagram:
arduino A0 : joystick VRy
arduino A1 : joystick VRx
arduino 5v : joystick 5v
arduino gnd : joystick gnd
arduino d13 : NRF24L01 sck
arduino d12 : NRF24L01 miso
arduino d11 : NRF24L01 mosi
arduino d10 : NRF24L01 csn
arduino d09 : NRF24L01 ce
arduino +3.3 : NRF24L01 vcc
arduino gnd : NRF24L01 gnd
upload the script to the microcontroller and follow the next step to build the reciever.
Step 3: Build the Reciever
connecting the reciever:
the reciever include 2 servo motors, 1 arduino, 1 NRF24L01 transceiver and a battery.
connection diagram:
arduino d3 : X servo motor
arduino d5 : Y servo motor
upload the script to the microcontroller. connect the batteries and you ready to run
here is the ready to run video
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    19 Discussions
    fenderblender
    Question 2 months ago on Step 3
    CAN YOU PLEASE HELP WITH THE RECEIVER SKETCH EVERYONE HAS THE SAME PROBLEM, THANKYOU
    fenderblender
    2 months ago
    wired up but cant load receiver sketch, i see at least 3 others have the same problem, why cant overclocker answer the question properly, the script clearly doesnt work, projects like this that dont work should be fixed or deleted from instructables...
    ArcR
    1 year ago
    Can anyone answer this: Why does the RECIEVER.ino code fail on the line "void setup()RF24" with error msg "exit status 1 expected initializer before 'RF24'"?
    Did you ever discover the answer to fix the code? I'm in dire need of this code due to a project I'm working on.
    EcoplanetTheRoguePhoenix
    Reply 2 years ago
    I also needed this code to work. Does anyone have a similar spell that can send me? I can not understand why this has the problem in RF24.
    If you do not mind sharing: cdi.com.ics@gmail.com
    giantpair
    3 years ago
    Why does the RECIEVER.ino code fail on the line "void setup()RF24" with error msg "exit status 1 expected initializer before 'RF24'"??? SHould have tried the codes before I wired it all up.
    RogerH39giantpair
    Reply 3 years ago
    I had the same problem. Did you get an answer or figure out a solution?
    skumar231
    3 years ago
    very good project ...if i buy electronic parts i try to make this...
    TheOverclocker
    3 years ago
    you can see 2 links to the scripts at the end of the post.
